FordGuy100
well, just got back from fall brawl. was at the spring fling with the ford and she made a wopping 123 hp and 254 ftlbs. that was before the turbo. since then i added a stock 7.3 turbo setup with crushed down pipe, hypermax cowl kit, and turned pump up 2 flats with plugged wastegate. today she made 161 hp, 320 ftlbs.
surprised a few people.
A conservative 20% drivetrain loss (most estimate between 20-30%) would net at the crank:
193.2hp
384 Ft. lbs tq
At 25% drivtrain loss:
201.25hp
400 Ft. lbs tq
30% drivetrain loss:
209.3hp
416 Ft. lbs tq
I would guess the 20%, so at the crank you made around 190hp and 380ft lbs. Not bad at all. Couple more turns of the pump should put you in the 200hp and 400 ft lbs at the crank range.
Stock OBS PSD was rated for 215hp (early models I believe) and 425 Ft lbs tq at the crank from the factory.
