Powerstroke ZF5 to a IDI truck?
frankenwrench
overkill is under rated!
Weatherford tx
Okay. Last question I do have a idi flywheel but don’t have the bolts that go into the crank. Any idea on where I could find those online
Not off the top of my head but in the tech section it has basically every part number and size known to these trucks. Il take a look
Christopher Cline
Washington
Perfect I appreciate it
I’ve never done this before and was just wanting to run this by you. Idi flywheel Powerstroke clutch and pressure plate?
frankenwrench
Weatherford tx
Honestly never tried that. Did the pressure plate for an idi as well as flywheel and clutch disk and throw out bearing. Just the powerstroke transmission. Some of it may work from the powerstroke, but I don't know it for a fact other than the transmission itself as well as the starter. But the starter is another topic. As for the question at hand, I used a luck clutch single mass flywheel and clutch disk and pressure plate for an idi.
Christopher Cline
Washington
Ok haha school me kn the starter you got me worried jow
frankenwrench
Weatherford tx
No worries, the first gen psd starter is the same and can be used on an idi. Having issues on finding the bolt specs for the flywheel. Hopefully someone chimes in with better knowledge than I on that particular matter
Christopher Cline
Washington
Thank you you saved me a massive headache haha
Wheelsrollin
