From my own experience; is the piece of hose long enough? I was trying to replace a piece of factory hose with a cut to exact length and could not get enough leverage to push it on. A friend took one look and told me it was too short. I bought another piece a couple of inches longer and what do you know, it slid right up. Sometime you just try too hard to make something work and just can't see the obvious.
You might want try an warm up the hose with a microwaved cloth, or heat up a tapered punch an use it to expand the opening enough to slide over the fitting - an old timer taught me that one while changing out hoses in the cold. Also, make sure the metal tube is clean and the opening burr/distortion free before you try again.
Also, make sure there is no rust/corrosion present. With all of the chemicals their putting on the roads, it seems as if corrosion is everywhere.
I know this sounds simple, but been there, done it, and learned from it.
