coletrain777
If I removed the front clip is there any problem with pulling the engine and trans together as one unit. I will use the front end loader on the tractor to remove it so I am not worried about the weight, just the feasibility. Any tips/tricks that you want to recommend are appreciated as well. I have to do a clutch job, oil cooler, and possibly had gaskets so I figured yanking the whole shebang would be easiest
