Where can I get the ones that are on top of the cab they are 5 with the holes on the sides, gray base with yellow top for a better description. Napa wants $11.85+ tax and I think they could cost less.
Thank You.
Thank You.
I got used ones!
if you have a semi truck dealer near by, check the cost of a 25760Y1 light kit from trucklite. That is box of 5 lights, gaskets, new sockets with pig tails. I got mine about 4 years back and the kit was $30 with shipping from the local Freightliner dealer.
If you need a laugh, check on the price of just the gasket from your local Ford dealer, it will be more than the light with gasket from Napa.
You might have them check the single light number 25760Y (missing the one at the end from the kit number).I just need the lights no bulbs or wiring just the plastic. I called a couple Freightliner dealers and they don't come up with the part on their system.
Since your in maryland, look up your local store called trick trucks, they should have a set of them, brand new oem style. they even have clear lens covers.
I know these aren't identical to what you have pictured but they're $5ea. :
http://www.delcity.net/delcity/servlet/catalog?parentid=790568&page=1
