Play in Steering
Cincinnati Guy
Cincinnati, Ohio
Ive been noticing here lately I have some play in my steering. When I turn the wheel to the right I get instant turning action, but when I go straight and turn to the left a get a lot of play in the steering wheel before the tires actually get turning. At first I thought steering box has the the play but wouldn't that effect both directions? Could Ball joints or a tie rod?
All the little bits of wear in the system can become quite additive. To track them down, try clamping different parts of the system so that they cannot move, and check for play at each step.
romulus
nor cal
i had the same problem, although i have a dana 50 ifs.
rather than diagnosing every little problem, i just replaced the steering box, all ball joints, and rod ends, pivot bushings, spring and shackle bushings.
total cost in parts was about 500 bucks, and a weekend of hard labor,smashed fingers, and a body bruise.
its tight now, just like a new one!
Cincinnati Guy
Cincinnati, Ohio
Well I dont have the $500 and to just throw parts at it...I guess I need to just go find out and try what Mel said to do.
We seem to be having a rash of cracked frames over in another forum causing problems in these trucks. It cracks around the area were the steering box mounts, and sometimes the rivets come loose where the large crossmember attaches to the frame rail.
lotzagoodstuff
Carmel, IN
Check the steering box itself, steering boxes get loose over time, especially with the weight of the diesel hovering over it. Be patient, having a friend help you with another pair of eyes as you are moving things and seeing where the issue(s) are.
Good luck.
SparkandFire
We're drinking beer
Aptos, CA
You're not really throwing parts at it... With all the years these trucks have been on the road hauling heavy stuff, and the abuse the frontend takes from supporting the engine and the heavy truck frame, 18 years is a lot of time and wear.
Like Mel and others said, the small amounts of wear throughout the system add up, a little slop here, a little slop there, before you know it the steering is terrible... That's what I am going through now.
Even if you can start replacing parts as funds become available, your better off.
subway
be nice to the admin :D
York PA
get a friend to wiggle the steering wheel back and forth in the truck only in the "play" zone. get under there and climb around until you see where the extra movement is going to.
thats where you can find it on the ground.
if you want to jack it up you can start grabbing tires and feel for any looseness. grabbing top and bottom checks the ball joints, side to side checks the tie rods, play all around is checking the wheel bearings.
Cincinnati Guy
Cincinnati, Ohio
Well all the play is coming from the steering box! Can I safely adjust it to take up some of that play?
Also checked ball joints and tierods by wiggling the wheel and have no movement either direction.
Did notice though my steering stabilizer shaft is bent to hell. Is the steering stabilizer shock suppose to be hard to push both directions, or is it suppose to be like a regular shock and spring out?
subway
York PA
you can try to tighten the box up but the play is usually in the center part of the gear so it will be fine going straight but cam bind when you turn. just make sure to test it out well before you take a drive on the road.
as far as the stabalizer yes it should be tight both ways otherwise it would only work when you turned one direction.
ohiozj
cincinnati
mine has got some play in it too. plus on the road around 40mph and above if im going into a sweeping curve to the right and hit a bump just right i get a little death wobble. not when turning left though, only right.
i had the wife turn the wheel while i looked underneath at the tie rods, they all looked good. i have to jack it up and check the ball joints or wheel joints i guess.
bring yours over and we can go over them together. i could use a fresh set of eyes.
HammerDown
Glenolden Pa
Where most of my play was...the slip steering shaft in the engine compartment has a 'spring' in it to take-up the slop well...mine didn't!
That = a LOT of slop and play. I carefully forced a shim up into the male/female slot and it's tight again ;Sweet
ntjapkes
