88 Ford
Do you plan on adding an ethier system to get it started sinc you are dropping the compression so low?
SWS
Ya or some sort of intake heater cus don't Virginia winters get a lil cool?
SWS
Actually, the intake heater on a powerstroke is only active below freezing during extended idle periods to prevent white smoke. It's only there for emissions. Nothing to do with starting.
I'm getting rid of the glowplugs because I don't want the tips melting off and doing damage anywhere else.
I'm going to compare the resistance of the intake heater vs the 8 glow plugs. If they are close enough I might try to use the GP controller for it. The heater will go into the hole on the back of the manifold where the CDR used to go. I got rid of the CDR to use the valley pan hole for the turbo drain, and to install a pan-e-vac system in the valve covers. That happened because at 4500 rpm, if that CDR starts to pass oil into the intake... runaway. Very bad day.
Its the PCV style caps in the valve covers that use a down draft tube to "evac" the gasses that would normally go through the CDR into the intake.
SWS
I just want to hear an IDI spinning 5000 rpm, as long as it is not mine.
Here we go, thats the kind of goodies ive been looking for. Glad to know there is someone who has gone slightly beyond what i am planning. Only real differences i can see are I will be running around 19-1 CR with an intercooled compound turbo setup, oh and i dont see myself spinning much faster than 4k. Which is all totally understandable as yours is built for pulling and mine will be more street /strip /towing. Im curious, how did you "shorten" the rods? I was thinking about offset grinding the main journals to destroke some if necessary to drop the compression. Im not totally sure if im sold on dishing the pistons, they are in alot of ways the "heat sink" inside the motor and less material would mean they heat up faster. Still looking into finding a set of forged slugs that can be transplanted into my build, and hopefully bleed off the compression that route.
Love the build and the pics, im sure im repeating, and speak for the rest of us, keep us posted!!
