wiguy
found this awesome '87 F350 CC in my sig for cheap I couldn't say no to! thing had been sitting with a no-start issue since last year which ended up being glow plug controller failure, when i got it home i was eager to see if it would start so i confirmed i had fuel pressure at the schrader valve on the filter head then disconnected the glow plugs and gave it a shot of ether. it started but made quite a valve racket for a couple seconds that went away but smoked white/blue pretty bad and ran rough for a few minutes. I shut it off then started it again- started fine still blew a little blue smoke not too much, took it for a 20 mile ride and the smoke gradually went away and it ran good with good power/oil pressure/coolant temp but i still have a little valve noise- i assume it's valve noise kind of cracking sounds i don't have with my '86. Question is did i screw anything up by using the starting fluid to get it going? Thanks for all the help, everything i now know about these awesome trucks i learned on this forum!
