The Ranger goes between the bellhousing and the transmission...which is why you cant use one with a ZF with the integral bellhousing This pic's from Ziggster's page:The Ranger III overdrive goes between the engine and bellhousing I'm pretty sure. They look like a pretty cool unit, I personally wouldn't mind the manual shifting, contributes to making the truck unique and a conversation piece and probably reduces the amount of people that want to borrow it. Tim are you sure you can't use a Ranger in front of a ZF5? Also if you find a DNE2 or someone else does, make sure it's from behind another ZF5 or a C6 as the 4 speeds have a different spline count and you would not be able to adapt them together.
And, regarding the spline count, how do you mean? Given that a transfer case that originally went onto a T-19 will fit on a ZF without any problem, I'm not sure how the same wouldn't apply to an OD unit.
FWIW my main issue with the GV's is that you can't use it in 4 wheel drive....if I had a 2WD I'd certainly consider one...
