aaron1976
Does anyone have an aftermarket overdrive unit on their truck?
I have an 87 f250 4 spd standard and was told it has on overdrive that didn't work.
I don't see anything in the drive trane that would equal an overdrive. Wondering if someone could give me some info. Are they located at the rear axle/diff or at the out put of the transfer case? Mine is electric or it is wired in the cab but I see cut wires underneath.
I am sure it has been taken off but I may look into putting another one on.
The truck runs at 2800 rpm or so at 65 mph. Seems high, what to you all run for rpm:mph?
Any real reason to put another OD on the truck, better fuel mileage?
