ok who runs what in their ZF?
what fluid is in you SMF trans
  • Total voters
    34
  • Poll closed .
BigRigTech
Diesel junky
Nova Scotia, Canada
Syn AFT filled to the correct level.....I might take it out though, ever since I changed it I have to be just about crawling to downshift to 2nd gear...It was perfectly fine with reg ATF....Night and day difference between the two for only that issue. Shifts easily other than that and I plow with this truck all winter so it get's lots of use.
alienturtle
Human
Ripon, CA
whats the difference between normal and overfilling besides the obvious fluid level? Or, why would it be worth a difference?
when you go SMF the zf5 is prone to "gear roll over noise" most the time at idle with the clutch out. The gears inside the tranny are actually rattling together because your flywheel no longer has springs in it to dampen the engine pulses. Over filling the tranny helps quiet the noise down
hesutton
The Anti-Anderson
Bowling Green, KY
Royal Purple synthetic ATF (not the synchromesh). 2 gallons (obviously that's overfilled LOL).
Chris had serious trans temp issues in his running the synchromesh stuff.... like 420+ and a very hot shifter.
Heath
tenlug
Reg ATF. DMF. Normal level. 270,000 miles. Steve
sle2115
NRA LIFE MEMBER
Southeast Ohio
Heath
Great...something else to watch for! lol I've not experienced that at all, noise is very low, everything seems to be working fine for me. I've used it before with good results as well. Had it in my T19, but I think they are pretty rugged as long as they have something in them.
itsacrazyasian
residentcrazyasian
boca raton, fl
i noticed that too! its nonexistant with the MTL.
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
couldnt find anything in time, so just grabbed 2 gallons of regualr ATF for now. can swap it out later. still curoius what everyone is runnin.
JU57US
