LOGANSTANFORTH
- Joined
- Sep 12, 2007
- Posts
- 99
- Reaction score
- 0
I need a pump that will mount on the frame rail of this truck, not in the engine bay, or up on the firewall, or anywhere else...It has to mount on the inside of the frame rail...
The Summit pump I bought will not suck out of the tank correctly, it cavitates...No one carries the right Carter pump apparently and Holley says the red pump won't work unless the inlet and outlet are level with the bottom of the fuel tanks and its within 12 inches of the tank which we all know is impossible...
So what will work correctly...This guy is getting pissed cause I don't have his truck done...Will the Holley pull from both tanks perfectly or will it screw up just like the Summit, as the Summit and it are almost identical? I am about to just go put a 60 dollar Mr. Gasket pump on it cause its the only one that is actually rated properly unlike any of the other pumps...
