Ok going full Dr house on this *****
greenskeeper
PA
Yeah like 4th cps all napa crap and icant get it to stutter or shut down tomorrow ihave all day for it nothing out of the ordinary no codes of course I didn't take it loaded down a dirt road first
When it shuts off does the WTS light illuminate?
Water in IDM ?
Jake95511
Arnold, MO
Long time lurker here, I have a 96 that had a similar problem. Truck would intermittently shut down and wouldn’t immediately start up again until it cooled off. The problem turned out to be the IPR/fuel heater harness that runs under the fuel bowl.
Larry Keys
Corpus Christi , Tx
I have a 97 f350with a 7,3 and a 5 speed it has a intermittent cut out and a full shutdown when pulling I can't het it to do it with the scanner data logging in the like 13th mech to have it I can't find anything any ideas
Well sir, i got a similar problem on my 2002 7.3. Running down the road at 70, it feels jerky, especially with the cruise control on. Like a little miss. Heve replaced every sensor, and have 65 lb fuel pressure. 2 sets of injectors, idm, and hpop. Nothing help's. Any suggestions anyone?
HarryLodge
Des Arc, Ar
I have run into this. Nearly drove me nuts. What fixed it was pulling PCM connector and putting diaelectric grease on it. I have fixed two that way. Both were stalling under load. No codes.
greenskeeper
PA
good point. The newest version of these trucks are 18 years old. Wouldn't hurt to spray dexoit and clean both the harness and pins on both the PCM and IDM.
Oledirtypearl86
Whitehall MT
Oh snap just got it to shut down tomorrow n me and the WTS light came on it happened as I was making a left hand turn at 65mph
Oledirtypearl86
Whitehall MT
Yes the fuel bowl heater is still plugged in and intact and ignition switch feels tight no extra slop no more than usual
m2rtin
