Well, I lurk here and learn lots but usually don't need to post questions as someone has already received the answer...but I'm not finding the answer easily.
I just put my 7.3 back in following a long drawn out reseal, clean, rebuilt heads, oil cooler, turbo, injection pump, new injectors, lift pump, water pump, etc. I filled the radiator with water and coolant flush (no antifreeze), to perform a better coolant system flush on startup and then refill later with antifreeze. I was performing intermittent engine cranking last night to get fuel flow started out of the tanks. After deciding to siphon some fuel through the lines, I quit for the evening.
This am the garage floor is covered with 1-2 gallons of oily coolant, a slow drip is coming from the bell housing bottom plate, the radiator appears empty (or low) and the dipstick is very high with oil/water (coolant). Obviously I have an oil pan full of foreign liquid that needs draining ASAP. There are no other visible engine leaks around water pump and oil cooler.
My questions are:
Any easy way to identify whether the coolant is coming from the oil cooler or water pump? Since it didn't ever fire and the huge quantity of coolant in the pan a head gasket leak would be unlikely. The engine has previously been sleeved on all 8 as well.
What else should I do to prevent internal rusting, damage while trying to identify the cause?
What other sources of coolant should I consider that would dump gallons into the oil pan while sitting overnight?
Thanks for any advise.
My questions are:
