oil leak
David
97 rear timing cover leaking bad pull the engine or do it with it in goin to do head studs at the same time any tips
argve
Resident Fruitcake
Gwynneville, Indiana
It's probably because of a failed Killer Dowel Pin so I would recommend taking care of that while you are there. And I would probably just do the repairs with it in frame vs yanking it .
David
did the pin when i did the font seal but leaks just as bad coming from the back side of the cover
Alleycat
