wwwabbit
Mmmmm Diesel
So, I got a fairly major oil leak (a 80 km run into town and back has left some good marks on the underside of the truck, and when parked it leaves a puddle about 2-3 inches round after a few hours)
Plus there seems to be some small drops of coolant in that area as well. I attached two pictures, one being the bottom of the front mount of the oil cooler, that is where the coolant drops are. The other is the two bolts on the back side of the front oil cooler mount, they look like a good place to start for my oil leak, I can't see anything really "wet" looking above that top bolt.
So, is there oil behind/close to that bolt, is it normal to have that rubber o-ring looking thing between the two washers there? I am going to guess that I will need to re-seal it onto the block, that should seal the water and oil leaks... should it not?
This looks like a big pain in the butt job, as I can't see there being much room under there to remove this thing. I am going to guess that I need to remove the whole thing (both front and rear mounts) When it's off, should I replace the seals in the cooler it's self, or just don't touch it if it's not leaking?
