zmck150
Probably a stupid question but a while ago you guys helped me fix a rough idle problem I had, now I took the advice and changed the oil cooler rings and gaskets. Problem I had originally was I had a muddy oil mixture in my coolant, figured it was seals. Now that the oil coolers done I shouldn't be losing fluids to the wrong place anymore right? I haven't driven the truck much(maybe 2 fuel tanks worth) but I've now put a little over 2 gallons of antifreeze in it. ( two separate times 1 gallon each time) any ideas on what else could be wrong. There's no coolant in my oil. No puddle under the truck and no visible smoke from the exhaust (no smell either). Is it possible that I hadn't bled the system correctly and had a 2 gallon bubble? Thanks in advance
Sent from my LG-P659 using Tapatalk
