trythis
Thank you for your time and interest I will be working on this in what ever time I can find and post anything new.
yes you got it I have been using the truck like that for a bit now. local stuff have run about a tank of fuel through it. runs okay, smooth, but the problem now is it is still getting oil past the orings on the injectors. and did replace the oringsThey were likely holding the ebpv open. Lol
I think oil is getting past because the fuel in the tank is dark and the oil consumption is vary high.I would clean out the bores. You can actually buy a brush set for cleaning them out. Plus making sure the bottom is clean where the copper washer goes.
Why do you think oil is still getting past?
Ok so the middle o ring is the one that would be letting oil into the fuel. Right? pink alliantCoolant doesn't go through the injectors. Oil comes in between the top and middle oring. Fuel comes in between the middle and bottom oring.
Coolant does flow around the injector cup.
yes that is why I got the inch lb wrench 10 ft lb is pretty touchy when mashing o ring and copper. but i am sure I got that part right7.3 PSD injector hold down bolt is 10 ft/lbs
