No power!!!??
Bootzz
Louisiana
12v is in and hooked up my battery but no power at all!!!
I'm gunna check voltage on my batteries when I get a meter in a Lil bit but what could I have cut or undone for this??
Could my cluster being out cause this??
kc0stp
30 Hour Famine
Colorado
Did you wire it up correctly? Fuses? Battery voltage? (Im assuming your talking about your cummins swap at least...)
You need a battery out of a Dodge. Those Ford batteries will never work, since IH made them. :p
Cruel but funny just the same.. Like posted already. What are you doing. Why is the cluster out of the truck. I really don't think the cluster has anything to do with no voltage anywhere. Start testing at the battery abd work towards the block. See where the open circut is.
Bootzz
Louisiana
Just noticed I never answered this
But my problem was I forgot to put a main power wire back to the solenoid on my fender well
Cv axle
