new zd9 glow plugs,new controller,
Really frustrating when it won't start cold with all the components you've replaced.
Starting at the batteries. Charge them for a full 10-12 Hrs. overnight or more, at least at 10 Amps.
Turn the headlights ON for 4-5 minutes to take the surface charge off. Wait 20 minutes for the batteries to recover, then do the check.
Next Day:
If you have a battery Hydrometer and the batteries are not maintenance Free, check each cell for specific gravity, The Sg. should be ~1300 or above, if one or more cells are below that, the battery is failing, disconnect POS on one battery, check voltage of each battery, should be 12.5 to 12.8 possibly higher.
Connect batteries back up. Hook voltmeter POS lead to the GP wire side of the ZigZag strip side on the relay. Cycle the glow plugs while watching the meter, should start out at battery voltage for a second, then drop to 9 to 10.5 VDC, anything below that, the battery voltage is not high enough to push the needed current to heat the GP's. fully. Make sure each GP has a good corrosion free connection and all the GPC connection are tight.
You can do the above with just one battery, if there is a difference between them, then that battery is failing. It could be that one battery is sulfated. I know you said the batteries are just one year old, but they can fail at any time. If you do the above, please report back the results.
