crash-harris
Breaker! Breaker!
Good point, I've been scatter brained recently. Terminology is suffering
The adjuster is only connected by the front cable and the rear cables to the drums. You may need to adjust it as well, but do yourself a huge favor and take it off the truck and soak the entire thing in penetrating fluid. Like submerge the whole assembly in PB Blaster. The threaded rod is a very small diameter with that large nut on it for adjustments, but if you go turning it, most of the time it'll will just twist in 2.
I have designs to make a beefier one, but other things have come first, so I haven't gotten to it yet.
For the clutch you need to replace the pedal box bushings and the clutch arm bushing.
Yes, that's the one that will fail just as plastic-craptastically as the OEM. If you want to actually FIX it, two choices:Is this what is used for the clutch arm bushing? http://shop.advanceautoparts.com/p/...ent-14041/9110078-P?searchTerm=clutch+bushing
On the shaft between the pedal and the arm. Notice how the pedal is (of course) to the left of the brake, but the pushrod/master is to the right? Dunno what egghead came up with that design, but there's a shaft that runs between them, that rotates when you push the pedal. Rides on the bushings. Once again, if the bushings are so shot that the holes in the pedal box frame (bracket, whatever) are getting "ground" by the shaft, you get to replace the whole pedal box.Where is the pedal box bushing located.
