Wvdirtroad
Comment on the crack in the floor above. If you're decent with a welder I would do one of two things- see if you can weld the crack up without blowing through where the rust is or cut the area out entirely around the dent (looks like you're far enough away from those floor pan indentations) and bend a piece of steel up and weld back in. If you go the patch route you'll still have to bend up a piece of steel to fit that area and weld it, so may as well remove the cancer while you're at it. Only reason I suggest this, is plate patches will trap moisture between the plate and the original floor pan and its only a matter of time before that area rusts back out, especially if you don't attempt to weld the crack in the floor and moisture is able to seep in through it. However if you decide to just plate it, I would get a couple cans of spray on bedliner and do both the underside of that part on the cab, and cover the plate you weld in. I know the hole rusty metal headache from my time with CJ7's... lol.
