nicksorenson
I just bought my first Ford diesel. It seems like an Excellent engine. I've owned several Mercedes diesels and have learned quite a bit. But I don't know much about the IDI I just purchased (94 F-250 turbo diesel).
First, what are some things I can do to keep this thing in good shape? Is there anything I should change?
Second, I've got some air in the fuel system. It's a little hard starting after it sits for 10 minutes or so and white smoke on startup. How do I trace down those darn leaks?
Third, there is oil build up on the Turbo Oil feed line. Is that normal? Also oil in the turbine housing... Just wondering if I need to do something about it.
Lastly, the Overdrive clicks out once in a while. IT seems like the thumb switch on the shifter has a dirty contact. Is this probable?
Thanks so much!!
Nick
Thanks so much!!
Nick
