new member
slam1
Sarasota FL
New to this very informative,interesting site. Wanted to say hi. Also need a little info on my 88 f250 ext.cab 4x4 7.3. wondering about turbo kits and over drive tranny conversions,injector pump upgrades or adjustments for a little more h.p.any info. would surely be apprieciated . Jon
FordGuy100
Silverton, OR
Hello and welcome to oilburners.
There are three different providers of turbocharger kits, Banks, ATS, and Hypermax. Banks and ATS have both wastegated, and none-wastegated turbo's, although you can only buy the none-wastegated turbos used becuase they are only selling there wastegated models. All of the hypermax's kits are none-wastegated. Banks sells there kit complete, with everything from the turbo to the exhaust and gauges and what not. ATS and Hypermax sell there whole kits in seperate pieces, like you buy the turbo, then the exhaust, then the gauges, ect. The banks will run you about $2600, the ats is $2000 for the turbo and intake + you need to buy the exhaust and gauges, and the Hypermax is about $1600 for the turbo and intake + you need to buy the rest of it. So in the long run the banks and ATS are about the same, around $2600, and the hypermax is the cheapest at around $2000 for the complete kit. There always seems to be some used kits for sale on ebay if buying new is to expensive.
As far as the overdrive tranny goes, is your truck a 5-speed, or an automatic?
You can buy an overdrive from Gear Vendors, but they are spendy, like around $3000 spendy. I think there are a couple other overdrives available, but I cant think of any right know cookoo .
For the IP, you can turn the stock one up for more fuel. But if that isnt enough dps-performance sells Hot rodded IP's and injectors. The only bad part about dps is they are a pain in the a$$ to get ahold of, and sometimes there products have some problems.
Hope that helps.
sle2115
NRA LIFE MEMBER
Southeast Ohio
Welcome aboard!
This is the place with people to help you spend your money!!! ;Sweet
Make sure you check out the tech articles as well. Some great information there and again, welcome aboard!
Welcome to the site. Be sure to read the forum FAQ's at the top, and as mentioned, most newbies here find the wealth of info available equips them to ask more specific questions to speed the discussions. ;Sweet
Seven4eight
