New injector lines
Keep your old lines, the new ones are very prone to breaking.
dieselrulz
Seattle, WA
wn and (If they have any IDI`s) pull the injector lines off, and you will have a good set. Think I have probably 7 sets just in case, ya never know when I can`t find parts any more.
Good to know the Accurite Diesel Hard Lines are not a correct fit. Iam thinking you might have
You have any Junk Yards in your area? If so head down and (If they have any IDI`s) pull the injector lines off, and you will have a good set. Think I have probably 7 sets just in case, ya never know when I can`t find parts any more.
Good to know the Accurite Diesel Hard Lines are not a correct fit. Iam thinking you might have to massage them some.
Any chance you want to sell a set?? I had J&M Diesel in Lynnwood WA replace my return lines/o-rings and they did not replace the clamps. caused a couple lines to crack. I searched and searched for OEM and found nothing. I didn't want to, but eventually tried amazon knock-offs. first set had entirely wrong nut size. second set sounds similar to accurate - i had to massage them PLENTY just to get the nuts to line up correctly. it would have taken a mandrel bender to even attempt to get them to plane. they seemed stiffer than my originals, so i crossed my fingers... but here i am 6mos later with a cracked line again. (which i suspected, and you probably already knew would happen w/o clamps.)
I am going to start calling junk yards monday, but my truck is parked until I can find a set. not buying another knock-off/doesn't even come close to lining up set of lines...
