hotshotidi
here's my parts list
50 gal freightliner tank, facet duralift pump,gates rubber bio safe fuel hose,3/8 synflex air brake line,napa filter head and a big water separator filter a two prong plug,a relay,wire,wire loom ,some heat rated wire loom. I got power from my aux.fues block and the trigger wire from my gpc. All connections are compression fittings and wire was heat shrink connectors then heat shrunk over that .on my relay prongs I used dielectric grease to protect it.
