FoMoCo
I had a clogged condenser and I installed a new one along with a new drier and O-tube. I removed and drained the compressor overnight and I ran thinner through the evaporator since this would be the only thing to hold oil, I also ran thinner through the lines. I wanted to get the correct amount of oil. I added 1 oz to the compressor and then reinstalled, I then added 6 oz to the drier to get the 7 oz as noted on the label. I did spill just a few drops so I should be just shy of the oil needed. I pulled vacuum and had a leak at the o-tube quick connect, so i resealed and check vac, look better, but my low side quick connector is not to good so it is hard to tell how good the system is. Anyway after pulling vacuum several times I decided to charge the system. I had a partial can that went in as liquid on the high side and then one full can as vapor on the low side, this can went quick. I went to the next can and took a long time and the compressor would only kick on for about 2 to 3 seconds and then stay off for awhile and then kick in for about 2 or 3 seconds again. The low side would be around 45 to 50 and then when the compressor kicks in it would drop very fast to around 25 and kick off. The high side was around 200. The system is working since just past the o-tube the pipe is cold and getting water. Should I try another can, or start over. Is it normal for it to take a long time to add freon? I guess since the compressor is not cycling very long it would take a long time to charge??
