An A/C question
If you change your R-12 components to 134 components won’t you have to buy new hoses because of the difference in fitting sizes?
You probably will have to change the fittings/hoses. But he is using the original components from what I read in the thread above.
Some fittings are the same size, some are different. Condenser inlet on drivers side is the same, outlet is different. Orifice tube quick disconnect is also different.
IDIBronco86
