fields_mj
I did finally find the 6 pin round to 7 blade adapter from Hopkins. I think I'm just going to remove the 6 pin round, and put in a J box, then intall a 7 blade milti plug with an additional 4 pin connector. That should cover everything I will ever pull, and on the odd case I run into something else it will be easy to tie it into the J box. It will cost me a little more this way, but sometimes saving $20 to $30 just isn't worth the headaches, and it will still be less than half the cost of the OEM connectors that I've found that still wouldn't fit the truck without some additional "customizing".
