bbjordan
Snow Monkey
Could be that it is retarded. Could also be that the outer ring on the harmonic balancer has slipped. It's a possibility. Very slight possibility however.
after you connected the meter, before you started the truck, did you reset the meter and make sure you saw 00000?
it means you're retarded, literally
now advance the IP 2 dimes width and check again.
DO NOT MOVE IP WHILE ENGINE IS RUNNING.
TWO DIMES THICKNESS....not WIDTH
alright you ********, if you wanna get technical, a dime only has a diameter and a thickness.
no width![]()
