Need opinions on clutch
Macrobb
North Idaho
LUK 07-225, here's some searches: http://www.ebay.com/sch/i.html?_odk...0&_trksid=m570.l1313&_nkw=luk+07-225&_sacat=0
I'd also look at rockauto, amazon etc. Pretty much any 12" SMF kit will do just fine.
I put a Valeo 53052006 in my '92 with 7.3; aside from the definite rattle at idle, it does just fine.
I actually put the flywheel on by itself first, and fired the engine up watching for runout(you can see a few thou of runout pretty easily), and it looked like it ran true, so I was plenty happy with it.
The kit I got was a 'damaged box' type thing off Ebay, and I only paid $208 for it. Really good buy.
I ended up buying a luk flywheel and clutch kit separate and it was actually a little cheaper than the kit. Still came with the same hardware etc. Just an FYI. My Luk makes no discernible noise at idle. Growls a bit lugging around but I think that's to be expected. Fuel system makes all the difference here I believe. Smoother the engine the less gear noise you will have. Russ must have done a great job on my injectors.
