jaluhn83
I'm surprised he didn't replace the accumulator. Everything I've seen says it's strongly recommended anytime the system is serviced. But maybe he know something I dont.....
Update- I took it to my friends dad who has been in the AC business for 19 years and he helped me out. Vacuumed out the system, replaced the oriphace tube, and put all new o-rings, then recharged with r-12. It's been two days and it's still blowing ice cold.
List:
Forgive my ignorance, but where are the O-rings and how do you change out the orifice tube?
Regards,
You are correct... for where you live, replacing teh accumulator would be required as teh dessicant would be saturated after 10 years of a compromised system, , where I live as well, but where he lives, if you laid a worm out on the ground, it would be dust in a matter of minuits if it didnt get under ground. The dessicant would actually release any trapped moisture in a system that has been sitting empty for 10 years with bum orings, the dry atmosphere would suck it completely bone dry, like everything else. so no worries. The old guy knew what he was doing Gotta remember, sometimes us old farts have a trick or two up our sleeves that comes from being around a whileYea, I'm surprised he didn't change it either since they are only about $15-$20.... If you open an AC system more than twice I like to replace them.... NO big deal though if its blowing ice cold.... Def a good idea to split the connection on the firewall and replace the orrifice tube or replace it... They are known to get it dirty and plugged up... I'd stick with R12 too over 134.... It cools so much better in older systems.... Retrofitting will work if the condensor has small tubes in it almost like a radiator but if it has larger tubes like maybe 5/16 or 3/8 diameter that 134 just doesn't like to condense in them, thus resulting in higher cooling temps..... As for the license to buy r12... that is almost an epa joke.... I got my epa 609 cert last year online for $45.....
... just charge 150 psi of nitrogen in the system....
