my turbo build thread and other junkm pic heavy
Fordsandguns
Fords Rule
Eastland Tx
When I first started reading it on yt I thought idi too until i read 600 hp. All the wight up front like that I bet that thing does a wicked burn out.
Ididriver
Panama city beach
It must be one he'll of a burn out
That much weight in the front of an Oldsmobile
I can do a nice burnout with Ma turbo idi not even near 600hp!
seawalkersee
It needs a turbo...
KCMO
Just chimed in on this. Did you increase the pass side header size to make up for the extra flow or no? I am in the process of doing this with my PS turbo. I cut the manifold for the pass side up last night.
SWS
88beast
pa
its now 2 inch but way i see it if 2.5 is good for na and you want more velocity with a turbo a single 2 should be ok also area wise a 2 inch is about the same as the turbo inlet
stock is 1 7/8 this should also spool the large exhaust housing quicker because of the higher velocity you can feed a tiny turbo with a huge pipe itll go slower and spool later so reverse is also true
seawalkersee
It needs a turbo...
KCMO
I just looked last night...mine has a 3" inlet. I have to figure out what to do now...
SWS
88beast
pa
what you mean 3 inch inlet is the pipe 3 inches? or is it 3 sq inches?
im saying a 2 inch setup aint too much smaller than the holes in a t3 flange so its not restricting more than the inlet t3 flange
88beast
pa
ok time for some updates yall were askin
and if i remember tomorrow ill get more pick of the improtant stuff
i decided to add an ic in with the turbo found one cheap thatll do good
i mocked up all the plumbing
winter came faster than i thought so i had to do rockers sooner than i thought did the drivers pass will get done tomorrow
also tomorow if i got time finish the manifold up
then get ic and air filter and figure out oil lines and itll be done
also i got brackets for the mirrors i found a set from a chevy c60 or something they will work great
also picked up a winch an old warn
roller pics only may grab more tomorrow
Watchin this build cause it's outside the box...of norm...I like that in and of it's self for that approach....I think the IDI is fast becoming a NEW hotrod engine...hmmm Rat Rod.....-Drool
88beast
pa
no turbo progress today the rust was much worse than i thought.
fabbed up new rocker supports and half a floor tonight and didnt make it to the cab corner.
pics will get up tomorrow
88 Ford
San Diego, CA
You are so close on the turbo that you should finish it up already. Lol. But anyway, what is your estimated time on when the turbo setup will be done?
88beast
pa
i am close but im swamped with work lately but soon it should calm down lol ill problly take the gf out for dinner and a movie as a excuse to finish it without her bugging lol
pics uploading as i post
93f250idi
strokin
cadiz ky
i know the feeling about rust LOL, picked up a 79 f150 that was rusty, pulled the carpet up and the floor pan is gone!
edit: forgot to tell you im likeing the build! cant wait to see it done!
88beast
pa
ok pic time welds sucked the flux core mig aint too great but here we go
88beast
pa
you can see how bad it was it went up into the firewall area and back to the seat belt mount.
i had to fully rebuild the under rocker support but its strong as hell now.
so i still got a cab corner to do but thatll be easier than the rocker since i rebuilt all around it.
also i got to redo the seat belt mount and i was going to run it off that support in the back of the cab.
but if not ill keep it stock location and ill add some support.
either way its almost done with sheetmetal work and im happy with that.
93f250idi
strokin
cadiz ky
yea it looks pretty bad. mines not quite that bad. i gotta get some welding wire so i can get to work, dont want to fall threw the floor board LOL but really i gotta get it ready to drive daily by friday.
