my trusty rusty chevy
bigoilburner20
circleville ohio
Ok well My 01 silverado has a v6 the 4.3L its a good engine but most have problems with intake gaskets as does mine. So should I put new intake gaskets in and drive it til it goes cause I do have a big sludge problem. Should I spend money now and fix it or just save up money for a 5.3 engine and harness and hopefully my trans won't go out on me? Any help would be appreciated.
bigoilburner20
circleville ohio
no there is no coolant in the oil I have had the truck 40k miles and the engine sat since it was just put in at 121k i mean I change it every 3500 and the sludge is so bad when i draing the oil i have to use a screw driver to poke at it
tanman_2006
Seiling Oklahoma
Wow, havent seen that on any of our low mile GM motors. 4.3L's are tough engines, maybe try flushing with a 50/50 mix of diesel/oil and run it for a few minutes. After that give it a shot of auto rx.
As far as a replacement engine I'd look for a 6.0L and 4L80 from a 2wd 3/4 ton. Alot more power potential, same size block, tranny harness is the only difference, and that tranny is alot tougher.
720Diesel
