FordGuy100
Do you have gauges, pyro and boost? If you do what kind of EGT's and boost numbers are you seeing? I think the 6.2 has about the same safe boost levels as a IH IDI, so keep it below 12 pounds. And if your thermocoupler (egt probe) is mounted in the exhaust manifold, dont go over 1200* for very long.
If the 6.2 pump is the same as my 6.9 pump, this is what you have to do. Looking at the IP from the passenger side looking towards the drivers side, at the bottom of the pump towards where all the fuel lines go in, there will be a rectangular black plate with 3 little bolts. Take off 2 of them and loosen 1, so it will be easier to put it back on. Then you have to rotate the motor until you can see a allen screw in there. Use a good allen wrench and tighten it to increase the fuel. Just do it in short intervals of about 1/8". Thats if the 6.2 pump is like mine, if not, then its all wrong.
