Cowman, the fact that you ain't getting codes don't mean the TFT ain't bad. Matter of fact what you're seeing is exactly what I saw when I bypassed the TFT altogether w/ a fixed resistor in an attempt to to fool the TCM that transmission is always cold (so it would never command a lockup and I could use my manual switch as I please w/o throwing code 62) - trick works initially, but that evil thing is just too smart for its own good and after good 10-15 min of driving it would ignore the TFT signal altogether and default to its regular shift schedule, lockup and all. Point is, if the TFT somehow managed to fail in a "cold" but legit position (such as 30,000 ohms, which corresponds to 75-80F) then you won't see any codes for it (at least I didn't) but it will take a good long drive for the PCM to eventually ignore it and give you lockup back. And this cycle will happen every time you shut truck off and restart it again, regardless of actual fluid temperature. On the flip side if your TFT failed in a "hot" and again legit position (say 5000 ohm, which is around 160F) then you'll be code-free again and this time you'll have your lockup available from the get go, even when the trans is actually still way too cold (tried and verified w/ almost a full oil change interval on a 4700 ohm resistor fixing temp at 175F or so).
So yeah, drive truck around for a bit to warm the trans up (or leave her idling in drive w/ parking brake on for about 5-10 min), then shut her off, disconnect the trans harness connector under the brake master cylinder, break out the DVM and get to measuring some TFT resistance! I posted the color coding for the wires needed in your last thread IIRC. Sorry if I sound like a broken record there, but w/o knowing what signal the TCM sees you can't really try to explain its behavior.
Do spray some carb cleaner up the trans harness connector for the solenoid pack tho, and air-blow it dry - ATF ain't exactly the best electro-conducting media known to mankind, so if some eventually found its way into the pins for the TFT sensor wiring it may be jacking up the overall resistance of the circuit, which to the TCM means cold trans and therefore no lockup till sensor reading is ignored.
