mankypro
Learning Slowly...
Suddenly I'm having hard starts. Where before I could just turn the ignition and stomp on the accelerator and it took 2 cranks to start it, I need to sit on the starter for 10-15 seconds now.
It's 95 degrees outside. Not using block heater. The WTS light comes on like normal. I pulled a gp (this being the first time ever I've done this) and the tip is covered in black soot, bit the top of it has a fine whitish soot like material on it. When compared to a GP out of the factory bag the one I pulled looks structurally sound.
Before I pulled it I tried using my Ohm meter set to continuity test at 20 and couldn't get a reading from it. Sometimes when touching the terminal I'd get a 2 or 3 momentarily and then it would fall to 0 again. I think I may be doing something wrong here.
That said, I had the black lead on the battery neg terminal and touched the spade connector on the gp. Anyone care to help this newbie out?
I guess I could replace all the gp's and be done...
