Moisture on windows
Mikes91
Melbourne, FL
It's been pretty wet and cool here in Monterey, lately, and the truck's been getting lots and lots of moisture condensing inside the cab. Takes no time at all for this to happen if the truck is warm... takes forever for it to go away even with the defroster on.
The carpet is dry... no leaks. I just cleaned both drains behind the front quarter panels earlier this year.
Is this kind of moisture normal for these old trucks when sitting out overnight in moist/cool conditions?
jlayne
Bondo Bandito
Milledgeville, GA
roll the window down while your parking :rotflmao
my 81 does the same thing and it is a leaky windshield... it takes very little moisture to make one fog up.... you should also check the heater core and door/window rubbers... they get old and shrink so it might not leak enough to make a wet spot but it might let in enough moisture to fog the windows
Mikes91
Melbourne, FL
Doh! How can I check the heater core?
Thanks again,
Mike
highest_vision
Reqistered User
Boone, North Carolina
Do you smell any coolant/honeyish smells in the cab? Windshield ever fog up for no reason? Pull the glovebox liner out, and warm the truck up. Is the core bulging? All are signs of a failing core. Of course once it starts leaking onto the floor, its failed :mad:
Good Luck
James
jlayne
Bondo Bandito
Milledgeville, GA
Thanks again,
Mike
if a 91 is like the 95 i replace a core in, if you remove the glove box you will see the heater box and it will have a access panel to get to the core with about 6 screws in it... remove that cover and the heater core is right there... feal around on it and see if she is wet :D if it is all you have to do is take the hoses off under the hood and one more screw and its out
the truck i fixed didn't leave a puddle in the floorboard but fogged the windows like you said... it wasn't leaking anymore than to leave a little puddle in the heater box... but it did smell like syrup (antifreeze) pretty heavy in the truck
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Shameless plug :D take a look here...the '87-'91 trucks should be similar. :)
If that's not it and you find the cause, I'd love to hear what it was...I've had the condensation problem the entire time I've had the truck (OTOH, I think my rear window now leaks :mad: )...
Dsl_Dog_Treat
Decatur,MI
:D
Have the same issues but we get some temp vairations due to winter. No brainer there, but Goldie also gets a little extra moisture pickup with the drivers floor pan having a few holes rusting thru. Till spring they can grow all they want but afterwards a few new pieces of sheet metal tacked into place
should solve it.
