ididieseler
what kinda mileage can i expect from a 4wd 7.3 with banks sidewinder and zf5 trans 4.10 gears and 35 12.5 15 tires. how bout 3.73 gears? or 3.54?
How are you all getting these great numbers? My running average is 12.1.
we can't touch those 2wd srw pickups with our 4wd duallies.but we can haul and tow without effort brother.
how you fitting 15's on your truck?
I've got almost the same setup, but do not have a turbo. I have a 4 inch lift, 4.10 gears, 35x12.50x16.5 BFG All-terrains, stock 1989 7.3 non-turbo, 143,000 miles, nothing ever done to the engine. With the c6 I was getting 12mpg, then I swapped in the zf 5 speed, and I now get 15mpg.
I will call some of the other guys out that are getting 19mpg; What type of fuel are you running? I am running pure watered down diesel from Krogers grocery store that I get a discount on when my wife buy's enough groceries. If you are running anything else, then of course you are going to get better mileage.
Taking out the lift and running regular tires, and then adding a turbo may help my numbers some, but I wouldn't think it would help that much.
better than nothingany answers you get wll be null and void because you are putting the engine in something with completely different weight, aerodynamics, and everything else that determines mileage.
just throwing that out there
