Metal dragging sounds????
moto-xking1313
eureka/ca/us
So the trucks been sitting for about a week. Start her up and as soon as i leave my driveway it sound like im draggin some metal :dunno. I checked just about everthing i can think of i cant figure it out. Any ideas? the sound is coming from the back
Mat J
Way down south
Jupiter, FL
something with the brakes hanging up?
jack up the truck and spin the wheels then put it in gear and see if you have any noise.
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
I was going to say brakes too. Check to make sure that your exhaust isn't touching your driveshaft or any other parts of the truck. I had that happen on my 1996 F150 before. There is a heat shield between the exhaust and the bed/cab...make sure that isn't dragging on the driveshaft.
moto-xking1313
eureka/ca/us
i checked the breaks and there was a spring rubbing and i fixed sound continues? theres nothing on the exhaust or driveshaft that was my 1st thot. idk im stumped:dunno
thanks for the help im gonna look into it more 2nite
Goofyexponent
Mentally Unstable..
I'm not doubting you, but are you 100% the sound is coming from the rear?
The front calpier pins are still in place so the caliper won't rub on the front wheel?
There aren't any broken springs that are rubbing the wheels or frame?
Dust shields contacting the drums?
Rocks or anything inside the rear drums?
Other than that, I would put the truck up on jackstands, chock the front wheels and run it in gear with someone in the cab. That would be the only way I can think to diagnose the problem.
Keep us posted!
F350farmboy
The Hornet
N.E Ohio
I had a metal rattle sound coming from the '89 a few weeks ago. I thought it was something serious in the front, but turned out to be a rusted dust-shield on the front drivers side rotor dragging. That was a relief!
Still check for loose heat shields, exhaust, etc. It would help to have a friend outside the truck to help pinpoint where the noise is coming from.
Compu Doc
Middletown NJ
Just make sure the friend is not underneath the truck when your driving it :rotflmao. Yes it actually happened I read somewhere once. The guy underneath did not live to tell about it though but his friend sure did. cookoo
4x7.3NE
Mowoodchopper
ne
I had a metal to metal noise the other day and thought it was a brake, it was sort of it was the diamond shaped locking wedge that you drive in to actually hold the caliper in place. It had backed out and was rubbing on the wheel!
Goofyexponent
Mentally Unstable..
The caliper pins. I had one back out a while ago, I guess they are known to weasel themselves out. I was told to try and bent the ends a little to prevent them from backing out. I have two spares in the glovebox just incase.
4x7.3NE
Mowoodchopper
ne
Thats what I did was bend them a little. But I am gonna also get a couple spares, I crawled under my other pickup and it had one about out also!
moto-xking1313
eureka/ca/us
so i got it jacked up and the sounds dissapeared? check the exausht and suspension and i found the exhaust rubbing and a break line...still not it. I got her doin like 20mph and no sound:dunno...lowered and drove sounds there again. My best guess is its the rear t-case under pressure but why? I am not to familliar with these trucks yet but plan to be the way thing are going with itLOL so all teh help is greatly appreaciated thanks guys -josh
forcefed
Newark, OH
Sounds likes a u-joint froze up to me. I don't know but its a cheap and easy thing to check.
moto-xking1313
eureka/ca/us
The rear u-joint could be replaced so i droped the line to pull it and its frozen solid so hopefully this is teh problem but now i got anotehr how do i remove the frozen u-joint? i tried beating it out and its not budgen even after being coated in pb? any thots again thansk for the help guys.. they aer not greasable
moto-xking1313
eureka/ca/us
so i took it to my buddies house and we pressed it off it was in pretty bad shape. Got the new one in and it seemed to fix the noise. thanks guys ;Sweet:thumbsup:
m2rtin
