Metal dragging sounds????
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
Agreed! Good to hear it was an easy fix. I might add that greasable U joints might cost a couple dollars more, and require grease once or twice a month, but last a LOT longer than the sealed versions. Another option is to drill all four caps of the sealed type and tap for a grease fitting. A little work now saves a lotta grief later
sootman73
Wauseon, OH
also check the level of gear oil in the rear diff. when it gets really low it will start making noises.
