Jarlaxle
Bregan D'aerthe
I thought they made one...err, did they? If so, what truck do I need to find at a junkyard, and is it a direct swap for a 6.2 NA?
they were made from 91-93. it is a bolt-in for everything other than the oil feed for the turbo. that is on the front of the 6.5 block. there are minor differences on the head design of the 6.2 and the injectors, but it's a non-issue if you're going for a 6.5 block.I thought they made one...err, did they? If so, what truck do I need to find at a junkyard, and is it a direct swap for a 6.2 NA?
i stay with 91-93 pickup. no DS4 pumps. those showed up 94 and up.I'm going for a complete 6.5 TD conversion to replace a worn-out 6.2 Detroit. Are any years better than others?
Did the Stepvans get them after 1993 or not?
DS4 pumps were the ones responsible for PMD failures. google it up.
i don't think the mech pump vans had turbos.
