TorchMadness
I am trying to figure out what it would take to convert my 1989 F250 7.3L to a dually. Someone mentioned all I would need is the rims and tires because my rear axles already has the extra space. Any suggestions?
you might be able to get away with a chassis-cab axle, but I'm not 100% sure.
nope.though they may be slightly wider than a srw pickup axle,the primary difference in the f350 cab n chassis axle is simply the spring mount locations.if you cut and re-weld them to the proper pickup locations,your right back where you started without enough width to run duals.
there are only two ways to run duals on a srw f350 or f250.adapters or a drw f350 pickup axle.
CorrectGlad someone brought this up. So to make sure I'm understanding this correctly. If I want to turn my truck into a DRW I should pick up a rear DRW axle and not use a conversion kit. But on the front it would be ok to use the adapter kit? Does the adapter kit fit over front lock out hubs?
