GREASE FIRE
right now my truck will only start if it is warmed up, the block heater was plugged in, or i use starting fluid. If it sits overnight without the block heater, even in warm weather, it will not start.
Less than a thousand miles ago it started right up with no problems....
but it seems now that low compression could be the problem since i have checked everything else out.
has anyone ever used one of those harbor freight compression testers? are they "good enough" for our purposes? if so, what kind of numbers should be i be looking for?
the engine only has 170K but i have no idea what the previous owners did with it - perhaps it got a lot of abuse.
thanks,
paul
thanks,
paul
