boogyman2003
hello my friends I've finally found you. this is exciting and I'm hoping you can help me ... I am the proud owner of a 94 f350 k code 7.3 turbo dually diesel and man do I love this truck ...
but here's the caveat... I have read so many forums about the dreaded flashing od light .... ill tell you what I've done so far and maybe just maybe some one here can guide me in the right direction ... before I guide my truck off a cliff.so here goes ..... no led's anywhere . good grounds all cleaned and or replaced .. brake light switch is good park neutral switch on the side if the trans is good all connectors are good and clean instrument cluster has been rebuilt and tested tps ohm's out with-in spec vss also and all there wiring.... tcm is good put it in a truck that had no issues and drove it around for a week with no issues cleaned and reinstalled back into my truck I'm losing my mind guys ... ive invested close to 20,000 into this machine because its my dream truck oh also the trans was rebuilt and upgraded in april of this year ... and I've only gone maybe 20 miles since then on test drives what am i doing wrong ... please help me thank you !!!!
