Smart thanksJamb a thin piece of wood between the belt and the pulley groove.
Everything I needed to know thanks a ton PhilipYep coolant out of the weep hole means a bad water pump. When you replace the water pump, its a good idea to replace the thermostat too. For the thermostat only use motorcraft, and for the water pump I personally like the flowcooler one, it has an upgraded impeller to allow better coolant flow and is what i am running in my truck. When you install the new pump, the center bolts that threads into the timing cover need to be sealed due to being exposed to the oil. Either a thread sealant or silicone will work for this.
Yuh know what I’ll just do it rightI plan to upgrade mine to a Flow Kooler...some day.
I'm working on this right now. You need a new water pump. To hold the pulley you can wedge a large screw driver between one of the pulley bolts and the water pump shaft. Either that or you get the Ford fan clutch removal tool. Either way, that ******* is on there pretty tight. I had to get two really long torque amplifiers on my wrenches to get it to bust loose and I was the one who installed it last, lol. It basically is constantly tightening itself, hence the left handed threads.
Edit: Oh sorry, i guess you already got the clutch off. Sweet! Get an Airtex water pump. They are OEM. I think O'Riley's has them. I just picked one up from Ebay.
According to the Ford manual, you need to put thread sealant on the top two bolts and the bottom two bolts. The new pump will probably come with instruction, but if you have an original water pump you need to install the new top two shorter bolts. The new waterpumps have a lesser thickness at the top. If you install the OEM original bolts, they are too long and will run into the timing gear and rip everything apart when you start the engine up. So yeah... make sure you look at that. Or bar the engine over a couple times after you're done to make sure nothing is binding.
Thank youThe box should have the instructions for those bolts. I stole this pic for you. See the notation on the top two bolts? See the other notation on the top and bottom two bolts.You must be registered for see images attach
