loping at idle
nathan79
I have a 99 cummins that lopes at idle whenever I stop and push the clutch in. It does this for 20-30 seconds then smooths out to just a rough idle. It has a lack of power and runs a little rough at highway speeds. It has 188,000 miles on stock everything except a fass fuel pump and filter system installed 400 miles ago. Any idea on the problem? Thaks for your help in advance.
marblecrusher
Van Alstyne, TX
Do you have gauges? (fuel pressure, boost, and egt) If so what is fuel pressure at idle and WOT? Which FASS system was installed? Also have you checked for codes?
-Jordan-
wmoguy
Colorado
Have you checked for codes? My 01 did that same thing right when it was vp44 time. Check your codes on the dash.
placidoert
