Looking for.......
I've searched this form over and over, i know it's here but can't seem to find it.
Does anyone have a link or the chart for the headbolt/headstud torque specs, and pattern on a 7.3 idi ?
You aught to specify what your uasing, Headbolts or ARP studs.
Head bolts are a different procedure than studs.
Head bolts are installed with the heads on in place.
Studs are installed with the heads off the block, then heads are installed, then nuts and washers are put on loose.
The torquing sequence is the same for both. But the studs are bottomed out before replacing the heads. ARP has a special nut/washer seating procedure.
With either way, the threads have to be cleaned with a bottoming tap. Be sure and blow out any debris after tapping the bolt/stud holes.
Here is the intake manifold sequence. Head bolt sequence. Intake bolt torque is 25 - 32 FT Lbs.
ZTSpridgen
