Horton 996135 is what I started with - EC450 clutch for a DT466. There were a couple on ebay for $299 for round about a year that I was looking at but never got the money. Finally did get the cash but they'd sold. However, I found a different one, made by NREC, I think? Looks like it's actually a German unit. Thread was right, but wrong direction, I think because it was misboxed somehow. Aside from the thread mismatch this looks like it will work quite well, and I should even be able to reuse the stock fan. The horton clutches mount the fan on the front of the clutch which would have moved it about 2" forward and caused problems. Was figuring I'd need to just get a new fan from Horton as well. But, this one is setup where I can mount the fan close enough to the stock position for it to work I think. It's also a 2 speed clutch - most are on/off, but this one has a front plate with a row of permanent magnets that should cause some drag even with it off, so instead of on/off I should get something like 25% or 100% flow... hopefully.
The clutch I got was pretty easy to strip down to where I can machine just the center shaft assembly - not sure if any others are built the same way.
I had also thought about getting one with a 4 bolt flange and making an adapter and/or machining the clutch/water pump shaft to mount the clutch using the pully bolts - this would also get rid of the fan clutch nut either coming loose or being impossible to remove....
