tom37
Up until now I haven't really posted much anything as far as getting my beauty ready for the road.
Today I finished up the brakes, just shoes and an axle seal thats been leaking for many years along with new hardware. The fronts got rotors, new calipers and shoes along with a clean and repack on the bearings.
A while back I went thru and replaced all the rusty brake lines.
The old gooseneck hitch was welded to the frame and sometime thru its life it became bent pretty bad, I'm guessing maybe stuck real good and a tow truck with a dandy winch. So that got cut off, letting the frame come back pretty close to straight. A set of rear springs from U-pick-it, 5 leafs, 20 bucks a piece.
A fantastic rear bumper, 10 inch drop with a 5/8" flat plate and brackets clear to the frame.
I did up the door hinges and latch's, now they shut like new.
#1 and #8 GP's were replaced letting the control work much better but still not perfect. Both came out tough but in one piece.
Also cured the Fat man syndrome that had attacked the tilt column.
The boss let me have off tues to make a long weekend. The plan was to finish all of the above, along with getting the front end alignment.
This is where everything went critically WRONG.
About 6:00 tonight I was eating dinner and planning on picking up all the tools and old parts.
With everything picked up and put away(at that point I was able to find tools again)
So I grabbed the 6 GP's not yet installed and figured no problem, I can get these by dark. I should have been done and ready for the return kit from typ4 and then I would be ready to burn oil.
Welp #1 turned hard right from the start, so I worked it both directions, still turning really hard. Then WAMO, it turned easy, at that point I said many many bad words. Didn't even make me feel better.
The broken portion is stuck in the hole.
So I got the AC, airpump, alt, misc brackets out of the way. I guess tomorrow I will pull the rest of the misc items off the top of the motor and yank the heads.
I'm thinking,
1 the gasket kit of course.
2 a new valley pan if its not part of the gasket.
3 looking for opinions on if I should replace the lift pump or not while I got it apart.
4 if the fuel lines aren't leaking then reuse them
5 new heater lines and rad hoses
6 yank the rad and get it checked out
7 the tuna can crankcase vent should go
I don't think I can afford a IP right now. Based on what I have found so far I believe that the truck has 153,000 on it, the clock shows 53,000 so I'm just guessing.
I would greatly appreciate any input on the items that I should defiantly go after while I have it apart.
I'm thinking,
